MegaZero
Oct 09, 2020Aspirant
Can't disable devices on Nighthawk R7000
My problem is very simple. Hopefully there's an answer. I've done as much searching as I could, but I can't find any problems remotely similar to mine. Basically I'm using the Nighthawk app to manage...
MegaZero
Oct 12, 2020Aspirant
*Bump*
- Christian_ROct 15, 2020NETGEAR Employee Retired
Hello MegaZero,
May you provide us with the current Nighthawk app version you have installed (iOS or Android).
Christian
- MegaZeroOct 16, 2020AspirantApp version is 2.6.4.1264 on Android.
