MegaZero
Oct 09, 2020Aspirant
Can't disable devices on Nighthawk R7000
My problem is very simple. Hopefully there's an answer. I've done as much searching as I could, but I can't find any problems remotely similar to mine. Basically I'm using the Nighthawk app to manage...
Christian_R
Oct 15, 2020NETGEAR Employee Retired
Hello MegaZero,
May you provide us with the current Nighthawk app version you have installed (iOS or Android).
Christian
MegaZero
Oct 16, 2020Aspirant
App version is 2.6.4.1264 on Android.
