MegaZero
Oct 09, 2020Aspirant
Can't disable devices on Nighthawk R7000
My problem is very simple. Hopefully there's an answer. I've done as much searching as I could, but I can't find any problems remotely similar to mine. Basically I'm using the Nighthawk app to manage...
Christian_R
Oct 21, 2020NETGEAR Employee Retired
May you reinstall the Nighthawk app and update your router to the latest firmware version.
https://kb.netgear.com/000062418/R7000-Firmware-Version-1-0-11-110
Christian
