Haigger
Feb 12, 2024Follower
Can't download the nighthawk app
I have a C7000v2 modem/router and can't download the nighthawk app
michaelkenward
Feb 13, 2024Guru - Experienced User
This is in the hands of your mobile device. iOS or Android?
What happens when you try?
What firmware version is on your C7000v2? It needs to be at least 1.03.01.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
If it isn't, then there is nothing that Netgear can do for you. The firmware is in the hands of your ISP.
