cindy914
Oct 27, 2015Follower
Can't find 5G network on my netgear genie
I seem to have lost my 5G capability on my router... cant seem to find how to set it up on my router.
ericaj79
Jan 27, 2016Aspirant
Both SSID is enable and I still can't find my 5G network.
- DexterJBJan 30, 2016NETGEAR Moderator
Hi @ericaj79,
Not all wireless devices are capable of detecting the 5GHz band. Please make sure that your device is dual band capable. You may refer to the device spec sheet normally found on the user manual.
Dexter
Community Team
- jwarstyleFeb 06, 2016Aspirant
I have the same issue, on all iphone the 5g netwrok disspaered at once. everything is enabled and updated with the r7000
- DexterJBFeb 07, 2016NETGEAR Moderator
Hi @jwarstyle,
1. Which iPhone model do you have? (iPhone 5 and above supports 5GHz)
2. Was it working before?
3. Are there other devices that are able to detect the 5GHz signal?
4. What is the firmware version of the router?
5. Have you tried resetting the router?
Dexter
Community Team
