Nazcar
May 18, 2017Follower
Can't log in to Genie
CG3000-2STAUS (CG3000v2) Model / Version: CG3000-2STAUS Via genie app on my phone, I am not able to login locally or remotely.
Hunter6986
May 19, 2017Aspirant
Try using the password "password"that's probably the default like mine
michaelkenward
May 19, 2017Guru - Experienced User
That is to login to the genie's interface to control the Netgear device.
Before you can do that you need to login to the wifi. That will have its own password and "username".
