elmatero
Apr 11, 2022Tutor
Can't log in to Nighthawk app (R6400v2)
Hello. I Have problem with login to Nighthawk app. Everything was working normally suddenly app has asked me for router password and won't accept this password. Replay is: Logon timed out please try ...
Apr 11, 2022Guru - Experienced User
Your not the first we've seen with issues on the app.
Most resort to just logging in through the browser.
- elmateroApr 12, 2022Tutor
I'm paying for Netgear Armor and the only way to enable or disable this service is to use Nighthawk app.. that's why i need it.
- plemansApr 12, 2022Guru - Experienced User
If its causing an issue with using armor, you can go through support as well.
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
