elmatero
Apr 11, 2022Tutor
Can't log in to Nighthawk app (R6400v2)
Hello. I Have problem with login to Nighthawk app. Everything was working normally suddenly app has asked me for router password and won't accept this password. Replay is: Logon timed out please try ...
Apr 22, 2022Guru - Experienced User
elmatero
Apr 26, 2022Tutor
I have already know, that restoring to factory setting fix it. I have done this actually three times and always suddenly error with login appears. Netgear should diagnose what is causing it and fix it.
- FURRYe38Apr 29, 2022Guru - Experienced User
Did you factory reset and setup with the NH app again?
Does the NH app not work again after a period of time?
