mattcollins123
Jan 28, 2020Aspirant
Can't Log Into Nighthawk App, ONLY When at home on my own network
Bought my Nighthawk AC 2100 last August and really like it. Downloaded the Nighthawk app and worked great. Now, when I am at home on my own network and open the app, it defaults to the default userna...
DexterJB
Jan 28, 2020NETGEAR Moderator
Hi mattcollins123, welcome to the community! There are 2 logins for the Nighthawk app. One is for your NETGEAR account (email format with password) and the other one is the router admin credentials (username is admin and your router admin password). The app is able to detect if you are connected locally (at home) and will only ask for the router admin credentials. The router username will always be admin.
Dexter
- mattcollins123Jan 28, 2020Aspirant
Dexter,
Thanks for the reply. I do recall that now and makes sense. However, I don't seem to recall my admin password. The default "password" is not working and neither does my other Netgear password. Can I reset this?
- DexterJBJan 28, 2020NETGEAR Moderator
Hi mattcollins123, yes, if you have enabled the password recovery option, it will prompt you to answer the security questions that you have setup. If that was not setup or if you are unable to answer the questions, a factory reset will be the only option. If that's the case, the steps are provided on the link below.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
- mattcollins123Jan 28, 2020AspirantThanks for the help! I couldnt get the PW recovery tool to work, but I started guessing and was able to get in without a reset!
Thanks for the update! Glad to know you were able to work your way around it. :-)
Dexter
