sjohn_az
Jan 20, 2022Initiate
Can't Log out of NightHawk App
It seems on my Iphone, I cannot log out of NightHawk. Very odd as I had to create a username and password and it gives the option to Login by facial recognition. It even gives the option of 2 factor ...
Apr 06, 2022Guru - Experienced User
Any progress on this?
sjohn_az wrote:
It seems on my Iphone, I cannot log out of NightHawk. Very odd as I had to create a username and password and it gives the option to Login by facial recognition. It even gives the option of 2 factor authentification. But once logged in, it seems there is no way to log out. When I close the App, it opens up again without needing to Log in. Anyone else having this problem? Tech support had no solution. Said something about it being addressed in a later update. Somehow that makes no sense. You create an app that requires Log-in credentials that you never can log out of?
