icebear1
Jul 24, 2016Aspirant
Can't login for remote administration
Hello, I have problem with remote login. In Genie I have set Advanced>Advanced configuration>Remote administration>Enable remote administration ON Enable remote access for all Port number 65312 R...
DexterJB
Jul 27, 2016NETGEAR Moderator
Hi icebear1,
1. Have you tried accessing the device remotely (using a different network/data connection)?
2. I would like to confirm if the wired computer is within your network or a remote computer.
3. Have you tried resetting the router?
4. Have you tried re-flashing the firmware?
5. Were you able to test other firmware versions?
Dexter
Community Team
icebear1
Jul 27, 2016Aspirant
Hello DexterJB,
1) Remote administration not logins from any networks I tried (Netgear's home, 3G, foreign WiFi).
2) Wired computer is connecting from my home network
3) I didn't
4) Yes
5) I used older firwares which had issues (router needed often restarts to keep going) - downgrading the firmware wouldn't be a solution. There are no alternative firmwares for this router.
Is there a limit for maximum passord length for remote sessions?
I will try reset the router and will report back if the problem has vanished.
