klancaster
Feb 16, 2017Initiate
Cant login to openDNS from genie
I am trying to set up parental controls, my first error message says I'm not connected to internet, I took care of that and it looks like I am connected now.
But now it seems like I need to set sign in to Open DNS, but I used the same email and password for genie but with no luck. I looked for a link to sign up for Open DNS but didn't find one. I really need this feature for some control on my children's internet use, but am a bit frustrated.
- DexterJBNETGEAR Moderator
Hi klancaster,
You can sign up for an OpenDNS account via the NETGEAR Genie app. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/25687
Dexter
Community Team
Hi klancaster,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- klancasterInitiate
No, when I go to parental controls on the genie app, I get a message saying my router isn't connected to the internet, but clearly it is connected.
What should I do to solve this issue?
- martinlifeAspirant
I'm having the exact same problem - using an existing OpenDNS account. Genie just won't log in.
- Bsquared155Initiate
I was able to setup a NetGear account no problem.
I was able to locate and download the NetGear Genie app for Iphone. No problem. I can login and logout of the iPhone Genie app- no issues.
When I tried to setup my parental controls it required me to set up a free Open DNS account.
I was able to establish a OpenDNS account and it said my user is registered, HOWEVER, when I go to login to parental controls it tells me "Username not recognized".
I cleard everything out and tried it again, same issue.
I signed up with another username and password and it tells me that the user name is registered. I click on "Okay" and try to login, but still the same message pops up "User not recognized".
Anyone have this issue?
BSquared, that is exactly the same problem that I have had for years now. I have never been able to resolve it. It's quite frankly, unbelievable that they cannot fix this. I wish that I would have discoved this during my return period.
