skd304
Jul 09, 2022Initiate
Can't login to R7000 on Nighthawk App
I can no longer login to or access my R7000 router via the Nighthawk app. If I am connected to the R7000 wifi, the app will ask me to login with my admin credentials. After entering those and pr...
Jul 09, 2022Guru - Experienced User
Review this:
Make sure Local Network is Enabled for the app as well:
Try this:
skd304
Aug 28, 2022Initiate
Thanks for your reply.
For some unknown reason, shortly after my original post, I was able to reestablish a connection to my router through the Nighthawk app.
A short while ago, I lost access again, and the behavior is the exact same as before. The app will seem to connect, then prompt for Admin login to the router. It fails to authenticate every time -- "Logon timed out".
My router is using the latest firmware V1.0.11.136_10.2.120. I'm using an iOS device with iOS 15.6.1. The Nighthawk app has access to the Local Network. I have closed the app and restarted my phone completely clean. I have tried turning off Private Wi-Fi Address and Limit IP Address Tracking. None of these provided any different result.
I'm loath to go to the suggestion in your bottom link which is basically a full factory reset of the router. Are there no other options? How can Netgear allow this issue to persist, even as they try to push router management increasingly through their apps?
