nokonek
Aug 23, 2019Aspirant
Can't login to RAX40 with Nighthawk app
Nighthawk app is no longer recognizing my router user and pass. I have tried clearing cache/app/data, uninstalled and re-installed multiple times. I can log in to my netgear account, and then logging in router with admin creds simply says, "Login failed please re-enter the correct admin password for your netgear router." I can log in from a pc i can login from my phone using a browser, but no dice with the Nighthawk app. The app worked when I first got it, whenever it decided to update fubar'd it.
More details:
App version: 2.4.2.726
Phone model: Samsung Galaxy S9 (SM-G960U) Rev 1.1
Android Version: 9 Security Patch June 1, 2019
Any thoughts on how to get that to work?
- Retired_Member
I am too having this issue with the RAX80 after about three to four days. If you use the app to get to the router remotly it will connect the reboot the router. This is what I have had to do.
- nokonekAspirant
I was finally able to get the app to connect to the router, but I had to power cycle the router. Because I am connected directly to the GPON, I have to powercycle the GPON as well, so I attempt to stay away from rebooting the router too much.
- Retired_Member
I seem to have to reboot my RAX80 every couple days as I loose the ability to log in locally via the app oir PC. Has to be a memorry leak in the firmware or something like that.
