JimmyW
Mar 08, 2024Luminary
Can't login to router on iOS
I'm running the latest version of iOS on my iPad Pro, and I can't log in to my router either with the Nighthawk app or by trying directly with the IP address in Safari. In Nighthawk, I receive a mess...
Mar 11, 2024Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
JimmyW
Mar 11, 2024Luminary
Thanks. I disabled Private W-Fi Address, but still can't log in. The router will not accept my password and resents a screen to create a password.
- FURRYe38Mar 11, 2024Guru - Experienced User
I'd give this a try:
- JimmyWMar 12, 2024LuminaryThanks. I'm not inclined to go through this convoluted process to access my router on my iPad. I can access it on my pc and Androids if I have to fix something.
- FURRYe38Mar 12, 2024Guru - Experienced User
Ok. Can submit a bug report on the iOS device and see if this can get it working:
Good Luck.
