daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
wliu2
Jul 27, 2016Guide
I have a similar issue. I can login to my N300 router (WNR3500L) via routerlogin.net in browsers, but not from Netgear genie app in my windows 10 Pro PC. The error message is "Login failed. The router response timed out". I upgraded it to the latest firmware but it doesn't help. The only thing special is I set my router LAN IP address to 192.168.10.1 instead of the default one (192.168.0.1).
| Hardware Version | WNR3500L |
| Firmware Version | V1.2.2.48_35.0.55NA |
| GUI Language Version | V1.2.2.44_2.1.12.1 |
- DexterJBJul 27, 2016NETGEAR Moderator
Hi wliu2,
1. What is the version of the NETGEAR Genie program that you have installed?
2. Are you able to login using the NETGEAR Genie app/program on another device (smartphone, tablet, another computer)?
3. We highly recommend performing a factory reset after updating the router's firmware.
4. Have you tried uninstalling and re-installing the NETGEAR Genie program?
Dexter
Community Team
- wliu2Jul 28, 2016Guide
Hi DexterJB
Here are the answers for your questions:
-> 2.4.26
-> Tried my iPAD air 2. It was able to login once at the beginning. It even helped me to create a openDNS account, then complain no internet connection, even the browser can access internet w/o issue. And all logins failed thereafter. Looks my router (WNR3500L) is not supported by the Genie? Also on my PC, Network Map always shows connected devices correctly.
-> Factory reset not done. similar concerns as those above. Don't want to lose my settings
-> Yes, no luck with uninstall/re-install.
- DexterJBJul 30, 2016NETGEAR Moderator
Hi wliu2,
Your router model is not supported by the NETGEAR Genie program. You may refer to the link below for the list.
http://kb.netgear.com/app/answers/detail/a_id/24686/~/netgear-genie-supported-routers
Dexter
Community Team
