daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
jmizoguchi
Jan 18, 2013Virtuoso
power off the unit for 30sec, power back and use browser if that let you get back in
topper12
Sep 12, 2016Aspirant
THANKS for the advice. The reset worked for me. Pulled the plug for 1 minute and then I logged in with no problem!
- agent86Oct 04, 2016Star
Hello,
I have read this entire thread and none of the suggestions has resolved my issue. I installed the Genie app on my iPad more than a year ago - when the GenieApp was first introduced. I kept the app updated with all of the updates. The app worked fine with my router (WNDR3700v3). Suddenly, meaning just within the last two months, I was no longer able to connect using the Genie app - I get the message informing me that my "router is not found or is not supported." "Also, ensure the device is not connected to the guest network and IPv6 is not enabled". None of which are applicable. Clearly, my router is supported - just review the list. I have the lastest firmware: V1.0.0.38_1.0.31.
Recently, I wanted to begin using parental controls and discovered the problem. I tried many things such as removing the app and reinstalling it. I installed the Windows version of the app on my Windows 7 desktop - it does not let me log in. I also reset my router and rebooted it several times, which yields an interesting circumstance. After a reboot, I am able to log into the router without issue using the iPad Genie app until I attempt to access parental controls or some other feature, then the app prompts me to log into the WiFi again. Also, I recall the parental contorls feature prompting me with a message indicating that I was not connected to the Internet, which was false - I was certainly connected to the Internet. Whenever I attempt to log in using the Windows Genie App, this is the log entry: [Admin login] from source 192.168.1.12, Monday, Oct 03,2016 23:22:01. The error message: "Login failed. The router response timed out." Any attempt to access the router using Genie on the iPad does not generate a log entry. The Home button on Genie app on the Windows machine yields information about the connection. I am able to view the network map. But, I am not able to access Readyshare, Router Settings, or Parental Controls.
Finally, I tried entering the router ip address manually, but this did not change the result.
What has changed? This is the question because the app worked, at least for me, about two months ago - now, it does not work.
I would appreciate an answer because I need to initiate those parental controls. When I purchased the router, the parental controls was an inducement to the purchase. It is very disappointing now that I need to use the feature, the software on a supported router does not work. I feel Netgear needs to fix this problem and not ignore it like Adobe ignored problems with their Acobat software after version 9.
Thanks,
agent86.
- popeOct 15, 2016Initiate
this is happening to me as well and yes it is within the last 1-2 months. the reason i got the netgear was for the Genie app! i think it is when i upgraded app it started happening.
brad
- nekotruongOct 17, 2016Tutor
I use Nighthawj X6 (R8000)
i try to log in to Genie to fix me wifi password, but when i log to router it said am not connect to my rout (i use cable to connect my router and my laptop)
also it said no IPv6 is enable (i did got back and check my IPv6 on laptop is fine)
anyone have any idea how to fix it ?
