daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
Jalew
Oct 20, 2016Tutor
Wow. Came here for the same. Agent pretty much said what I was thinking. I can't wait to find a resolution to this. Thanks guys.
DexterJB
Oct 20, 2016NETGEAR Moderator
Hi agent86,
Thank you for your input. We have performed our own tests and we were not able to replicate the issue. The questions and suggestions I have posted for nekotruong was for isolation since he did not mention any other troubleshooting steps that he has taken. Others reported that uninstalling and reinstalling the app fixed it for them. However, if that has not worked then there is clearly an issue. We would like to investigate further on this. I have sent you a message. Please check your inbox.
Dexter
Community Team
- nekotruongOct 21, 2016Tutor
few day ago i kind of too busy so i didnt show you how i fix that problem.
the way I fix is simple, (note: i didn't do any step you told me) I just use the paperclip to reset the router to default setting by the small hole on the back of the router and hold for 7s or 10s, and that it i fix it (note: before the problem hapend i didn't change any setting in the router)
