daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
Stretch68
Dec 13, 2016Initiate
DexterJB. I have a Netgear WNDR3700v4 and no matter what I try I cannot login to the router to make changes. I have done everything you talked about in the previous comments and still no luck. Any suggestions?
