daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
DexterJB
Dec 15, 2016NETGEAR Moderator
Hi Stretch68,
1. What is the firmware version of the router?
2. Was it working before?
3. Are you able to login using other devices (Android, iOS, PC, Mac)?
4. Are you getting an error message? If yes, please provide a screenshot if possible.
Dexter
Community Team
agent86
Dec 19, 2016Star
1. What is the firmware version of the router? V1.0.0.38_1.0.31.
2. Was it working before? Yes.
3. Are you able to login using other devices (Android, iOS, PC, Mac)? No.
4. Are you getting an error message? If yes, please provide a screenshot if possible. Yes. The messages are different on IOS and Windows.
