daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
DexterJB
Jan 26, 2017NETGEAR Moderator
Hi hotshotjoe,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
LaurelC
Jan 26, 2017Initiate
I started having a problem with the Genie app yesterday. I need to monitor the traffic on my router and it seems that the only way to do it is through the Genie app router settings section. Yesterday, the Genie app started crashing so I reinstalled it after downloading it from the internet. At that point, I couldn't log in to the router setting from the Genie app. I then reset the router. That did not help. I still can't log in (yes, I know the password was reset to "password", but I logged in to the router via a web browser and changed the password there). But the problem is that I need the traffic meter!
The error I get is "Login failed! Please check to see if this computer is connected to the NETGEAR router." And, I am using the correct password and user name!
LaurelC
- LaurelCJan 26, 2017Initiate
I seem to have fixed the problem. I redownloaded the Genie app from the Netgear website. The site I had downloaded it from yesterday was CNET. Maybe the CNET version is not the latest. I can now see the traffic meter again.
LaurelC
- MVolkerFeb 11, 2017Aspirant
My router login problem is identical to what immediately preceeds this posting. I can log into my Netgear router via 192.168.1.1 wireless connection. Parental controls do not provide an option to connect to OpenDNS. Click on Parental Controls and it says "Checking router firmware." Genie tells me "You don't appear to be connected to the Internet. Please connct to the Internet through your NETGEAR router and try again." Pressing the button "Try again" returns the same result. When browsing to the router the Parental Controls status shows "Not Enabled." For some reason, it appears that Genie will not browse out to find the router, even though I can browse the Internet just fine. The Genie version I loaded comes from the Netgear website. The following recommended solution on this Community website did not work:
1. Install the latest version of NETGEAR Genie. You may use the download link below.
http://netgear.com/home/discover/apps/genie.aspx
2. Once you have successfully installed the program, navigate to C:\Program Files (x86)\NETGEAR Genie\bin
3. Delete the drivers folder.
4. Download the drivers from the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6bEVUbmxtUTY0MW8/view?usp=sharing
5. Unzip the file to your preferred location (Desktop would be easy to locate). It will contain the drivers folder.
6. Copy the drivers folder that you have just unzipped and navigate back to C:\Program Files (x86)\NETGEAR Genie\bin
7. Paste the drivers folder.
8. Relaunch the NETGEAR Genie programWhat next steps should I try?
- wallygMar 12, 2017Aspirant
first time using this foum. router is ac 3200 nighthawk x6 mod r8000
- wallygMar 16, 2017Aspirant
the model is ac 3200 x6 nighthawk r8000. i have upgraded to latest router firmware and updated to latest genie software. i have reset router to fatory setting.
still unable to log into router via genie software. now same issue on windows 7 pc. any help appreciated
- baddad828Apr 15, 2017Initiate
same issue. Nighthawk X6 R8000. Also tried uninstalling and reinstalling Genie. Still get same result....timeout when i try to log in admin and 'you don't appear to be connected to the internet' message.
- vickyraoApr 17, 2017Star
same here. still having the issues. done all i could on the router and setup and re installed on iphone and android and still the same. cannot login to my router from the genie app. but using a web browser has no issues.
Netgear, please help to resolve this.
