daveke
Jan 17, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 09, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
wallyg
Mar 16, 2017Aspirant
the model is ac 3200 x6 nighthawk r8000. i have upgraded to latest router firmware and updated to latest genie software. i have reset router to fatory setting.
still unable to log into router via genie software. now same issue on windows 7 pc. any help appreciated
DexterJB
Mar 20, 2017NETGEAR Moderator
Hi wallyg,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- baddad828Apr 14, 2017Initiate
same issue. Nighthawk X6 R8000. Also tried uninstalling and reinstalling Genie. Still get same result....timeout when i try to log in admin and 'you don't appear to be connected to the internet' message.
- vickyraoApr 16, 2017Star
same here. still having the issues. done all i could on the router and setup and re installed on iphone and android and still the same. cannot login to my router from the genie app. but using a web browser has no issues.
Netgear, please help to resolve this.
