daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
vickyrao
Mar 29, 2017Star
I am having the same issue since I upgraded to the latest version yesterday. I am able to login usin web browser. But using genie app on android or iPhone it fails. Tried reboot router and also tried reinstalling the apps. Still the same issue.
- MVolkerMar 29, 2017Aspirant
Abort the effort, the Genie GUI will not work on Windows 10 PCs. The only solution I found is to download the Genie app on my Android phone. It works fine from there.
