daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
chennadi
May 04, 2017Initiate
I have the same issues. It used to be fine after the major android app update.
But later there was a firmware update to X6 R8000 - V1.0.3.36_1.1.25.
The problem started afte this update.
Bigskeeter47
May 04, 2017Aspirant
I have tried to download previous versions of updates for my router. When I try to run the program I get a "disc corrupted" error. This occurs with all the previous versions listed for my router. Has anyone else experieniced this problem?
