daveke
Jan 17, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 09, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
NTGR-OPS
May 08, 2017Tutor
Same issue here.
R8000, have tried all the above steps to no avail, at least 5 times.
This issue has 25K views on this forum. I think a resolution is needed, or at least a workaround. Lots of folks affected.
NTGR-OPS
May 08, 2017Tutor
FYI, downgrading the router firmware fixed the issue for me, at least for the moment. I can now access the router through Genie on multiple machines, including IOS apps and PC.
