daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
Obnoxs2
May 09, 2017Aspirant
5/9/2017
I updated netgear and now have exact issue described above. Anyone have a fix yet?
jmeyers11
May 09, 2017Guide
This definitely appears to be related to the router firmware update. I bought a new router, setup genie, logged in, and everything worked. I updated firmware and it immediately stopped working and hasn't worked since. Netgear, help us out!!!
