daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
chennadi
May 04, 2017Initiate
I have the same issues. It used to be fine after the major android app update.
But later there was a firmware update to X6 R8000 - V1.0.3.36_1.1.25.
The problem started afte this update.
Spyderjohn
May 10, 2017Aspirant
Same issues here but with iOS on both iPhone and iPad. Cannot log in using genie but can using the safari browser.
