daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
jmeyers11
Jun 14, 2017Guide
I have this issue also and post above. No response or fix from support. I did fix this issue by rolling back to the previous version of the firmware. Works fine now. That's the only thing I could do to fix it.
- ivhansenJun 14, 2017Star
If only that worked. What version works? V1.0.3.36_1.1.25 not working here.
