daveke
Jan 18, 2013Guide
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed ...
- Jan 10, 2017
Hi jwilson484,
Please try the following steps:
1. Uninstall and re-install the Genie apps/programs from your devices.
2. Reboot the router.
3. If it is an option, you can try doing a factory reset on the router.
Dexter
Community Team
ivhansen
Jun 14, 2017Star
Yaw, one more downgrade then... And it can draw a correct network map? And you can block devices (wired/wireless) from Genie?
vickyrao
Jun 15, 2017Star
There was a new update on firmware and it worked for like couple of minutes and then gone again.
Maybe they are not responding here cause the thread is marked as Solved? I wonder. This is outrageous support service from Netgear. Really regretting getting this router now.
