Rol23
Mar 23, 2019Guide
Can't login to the Nighthawk app
Model: R8000P
I have used the Nighthawk app for a year now, no problems. Bought a new phone, tried to sign in to Nighthawk app, no error message, just always returns to the login app. So I tr...
- Apr 18, 2019
Holy crap, I got it to work!!!!!!
So read on another thread about clearing cache and app, then trying again. I did that a few times and nothing. I tried changing my passord many times too, that didn't work too. I removed special characters from my password, that didn't work at all.
So I am writing angry emails, angry post. I try one more time, force stop the app, then I cleared the cache and data. Next I went back to the nighthawk app and tried to login, I finally get the two step authentication pop up, this never popped up in all my attempts. It was linked to my phone and my email. So I selected email and entered in the code, then admin code and boom I am in.
I guess in short the solution is keep force stopping, clear cache and data, then try again until you get 2 step up. Also try and remove special characters from password if this doesn't work.
Netgear's support is crap, probably the last time I buy or suggest any of their products.
aphexx0407
Apr 15, 2019Guide
I tried that too but with no luck, deleted data, uninstalled/reinstalled app from the playstore. I was able to work my way around now inside the app but I still can't login to the Netgear Account hence I can't get the remote management On. I can't also use the Genie app as my router is no longer supported, asked me to install the Nighthawk app.
schumaku
Apr 15, 2019Guru - Experienced User
There are no routers no longer supported by the Genie App - what worked before does continue to work. Just click the nag notification away (or use the back button) and you can use the Genie App as before.
- michaelkenwardApr 16, 2019Guru - Experienced User
You can also install the Nighthawk app and use it alongside the genie.
Installing one does not remove the other.
- schumakuApr 16, 2019Guru - Experienced User
schumaku wrote:
There are no routers no longer supported by the Genie App - ...
Afraid, I must admit that the latest Genie update does indeed no longer allow using non-supported routers.
Browsing over Netgear Web and KB find that they admit that Genie App remains available for xDSL, cable and older router (including a few Nightawk models!).
Looking a little bit further does show that for the Live Parantal Control (LPC) only the desktop (macOS and Windows) can be used, any eferences to the Apps were removed.- Rol23Apr 18, 2019Guide
OP here, well now the genie app is no longer supporting my device. The nighthawk app is still down not work, I change my password, login, back to login page. Killed the data, uninstall app, still same issue. I can login to the website, and I see my router.... I can manage it locally.
How about an error message in the nighthawk app, something to tell me what the $#@!#$#@ to do... How about any support at all, i spent a bunch of money on the router and a netgear modem...
