Rol23
Mar 23, 2019Guide
Can't login to the Nighthawk app
Model: R8000P
I have used the Nighthawk app for a year now, no problems. Bought a new phone, tried to sign in to Nighthawk app, no error message, just always returns to the login app. So I tr...
- Apr 18, 2019
Holy crap, I got it to work!!!!!!
So read on another thread about clearing cache and app, then trying again. I did that a few times and nothing. I tried changing my passord many times too, that didn't work too. I removed special characters from my password, that didn't work at all.
So I am writing angry emails, angry post. I try one more time, force stop the app, then I cleared the cache and data. Next I went back to the nighthawk app and tried to login, I finally get the two step authentication pop up, this never popped up in all my attempts. It was linked to my phone and my email. So I selected email and entered in the code, then admin code and boom I am in.
I guess in short the solution is keep force stopping, clear cache and data, then try again until you get 2 step up. Also try and remove special characters from password if this doesn't work.
Netgear's support is crap, probably the last time I buy or suggest any of their products.
michaelkenward
Aug 01, 2022Guru
jimtino wrote:
Loved product but agree support is useless. Still cannot get back into app
You looking for help of some sport?
Explain the problem, what equipment you have and maybe someone can come up with some ideas.
Sadly "cannot get back into app" tells us nothing.
You don't seem to have posted any messages that could guide us.
Rol23
Aug 01, 2022Guide
Another thing I also found while setting up the router after I moved... If you run VPN on your phone or your computer, disable it. The app literally cannot work with any VPN running.
Hope all this helps, honestly why make pretty good consumer hardware and make the apps completely user un-friendly. To many infinite loops in the workflow with absolutely no helpful error messages. As soon as a good unify solution comes out for 6e I will be switching and never looking back at consumer products again.
