alexrivera
Mar 21, 2020Guide
Can't login via Nighthawk App
I'm trying to log on to my router via the nighthawk app and keep getting the follow error:
I'm on the latest version of IOS and the router is up to date regarding the firmware. I have also deleted the app, hard restarted my iphone, and reinstalled the app. When opening the app upon install, it runs through the netgear account setupo and I always have to select my email for verification because for some odd reason the push notification to verify doesn't function. Nonetheless, upon completing verification i get the error above. Any ideas to fix this issue?
Thanks. Alex
Login to what? R8000P or EX8000? Both appear in your footer.
To the R8000P. That is my primary router and EX8000 serves as the extender.
- shawnmanjiAspirant
I am having the exact same issue. It is driving me absolutely crazy! Have you found a solution yet?
- Christian_RNETGEAR Employee Retired
Shawnmanji,
Have you tried rebooting your router or reinstalling the Nighthawk app?
Christian
