jibjubja
Aug 12, 2022Aspirant
Can't remote to MR60 from Nighthawk app
I owned MR60 and R9000 Nighthawk. Last year, I turned on remote management on all my routers and could remote fine using web browser/nighthawk app on both devices from internet connection and my inte...
- Aug 14, 2022
michaelkenward
Aug 13, 2022Guru - Experienced User
jibjubja wrote:
Until I had updated MR60 firmware and recognized that MR60 admin page removed remote management for web gui.
Netgear has been removing things like that, probably following security issues.
We are now left with Anywhere Access.
Have you tried that?
It used to go under a different name:
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
jibjubja
Aug 13, 2022Aspirant
yes, I had tried to turn of/on for anywhere access on Nighthawk app but it didn't help. I tried to turn off my firewall if it might help, but still no luck. This MR60 is behind my firewall since its first day when it's web gui still supported remote management. Thank you for your comments anyway.
- michaelkenwardAug 13, 2022Guru - Experienced User
You have to enable it on the device before you can mess around with the app.
You also have to link to a MyNetgear cloud account.
Is there anything set up in Web Services Management?
- jibjubjaAug 13, 2022Aspirant
I already had linked MR60 on my.neargear.com since last year and i could use it fine until I upgraded firmware and nighthawk app, after that nothing seems to work.
And Yes, Web service management/local management, I checked for "Always use HTTPS to access router'.
- michaelkenwardAug 14, 2022Guru - Experienced User
