ReallyUnhappy
Jul 05, 2022Aspirant
CDI-API-FAIL error
the netgear nighthawk app just stopped working... Device Manager won't load, i keep getting the same error OVER AND OVER again. CDI-API-FAIL My router is online, the devices are accessing the i...
- Jul 06, 2022
We've been seeing it a lot more as apple has been defaulting to the icloud relay and private mac/ip address setup.
If its working, you can mark it solved so others aren't still trying to fix it.
(yes the app is slow. I'm not really a fan of it and i mainly use the browser)
Jul 06, 2022Guru - Experienced User
What version is it?
Is this an ios app or android?
if its ios, make sure private mac/ip address is disabled along with icloud relay.
ReallyUnhappy
Jul 06, 2022Aspirant
thank you!! that did the trick...
what's weird is that this only just happened in the last few days...
The app really could use some improvement, it's soooooo slow.
