JDG78
Aug 21, 2022Tutor
CDIL-API-FAIL RAX50 Nighthawk App
I have a Nighthawk RAX50 Firmware Version V1.0.11.112 When I use the Nighthawk app and try to see my devices, it gives me the CDIL-API-FAIL error message and doesn't show any of my devices. I can ...
- Aug 25, 2022
Not just icloud relay but you disabled the private mac/ip address settings as well?
Aug 22, 2022Guru - Experienced User
Are you using armor or parental controls?
Are you on ios or android?
If on ios, make sure icloud relay and private mac/ip address are both disabled.
JDG78
Aug 24, 2022Tutor
Thank you. I use parental control but not armor. I am using iOS on my iPhone. How do disable the iPhone relay?
