ljj870
Jan 21, 2018Aspirant
Cell net gear app connection question
Are the WNDR3400v3 series routers to old to use with the android net gear app?
It seems that the app is seeing my wifi, but when I go to login with the default user name and password, it tells me the device is not connected to the WiFi network, when I know it is. This occurs wether or not NetGear Genie is running on my labtop, and I can't acess it from remote acess. Also my router doesn't allow me to sign into my Netgear on the windows application.
ljj870 wrote:
Also my router doesn't allow me to sign into my Netgear on the windows application.Did you find this?
If you cannot login to your router | Answer | NETGEAR Support
Then again, not what what you mean by " doesn't allow me to sign into my Netgear".
my Netgear what?
- ljj870Aspirant
I meant to write the My Netgear Genie mobile app
Also I solved it the easy way, I bought a new router, was about time I upgraded to a better router anyhow.
