Raebecca's avatar
Raebecca
Follower
Jun 04, 2017
Cell net gear app
I have the net gear app on my cell. I am trying to log in using admin and password to change parent controls but it will not let me login.... help please...
  • Hi Raebecca,
    1. What is the model number and firmware version of your device?
    2. Please try using another device (Android, iOS, computer).
    3. Are you getting an error message? If yes, what is the error message?
    4. Please try uninstalling and re-installing the app.
    5. You can try resetting the device to factory defaults.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Raebecca,
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Raebecca,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
