DavidDuke
Apr 19, 2021Follower
Changing the DNS int he Nighthawk App
Hi, I can't seem to change the DNS in the Nighthawk app. Is this function disabled ?
Apr 19, 2021Guru - Experienced User
That needs to be done thru the routers web page.
michaelkenward
Apr 20, 2021Guru - Experienced User
And you can still get at the browser's graphical user interface (GUI) with a mobile device on wifi, even though it isn't really recommended.
Just fire up the browser on your mobile device and aim it at the GUI address in the normal way. It may look nasty, but it should work.
