RichMeyers
Feb 15, 2020Aspirant
Channel Interference for 5G Bands
Noticed that the mobile app has Channel Interfence for 5G set at 149 which is Average and has recommended several lower channels as BEST however 149 is the lowest I can set it to within the Netgear A...
Feb 15, 2020Guru - Experienced User
the R8000P is a tri band router. One is for 2.4ghz, one for lowband 5ghz, and one for the higher band 5ghz.
Nice thing about 5ghz is that it doesn't broadcast as far or for as long because data transfers faster. So even if there's some interference on the higher band 5ghz, it isn't as bad as the 2.4ghz band is with interference. And you have the other 5ghz radio you can use.
What firmware is on the router?
You can log in through the browser to do changes as well. I've found the browser tends to have better/more accurate info and have more advanced features than the app.
RichMeyers
Thanks for the reply. My firmware is: V1.4.1.42_1.3.4
I agree that the browser is better for making changes. I guess I will leave it at its current settings. Thanks for the reply.
- plemansFeb 15, 2020Guru - Experienced User
Its a little unfortunate that the 5ghz radios aren't universal but limited to high/low on the tribands but I'd imagine its to prevent people from having the channels set to the same and creating interference from the router itself.
