marekproc
Dec 06, 2021Aspirant
Circle profiles gone
Hello My Circle profiles just disappeared. I performed a Circle Profiles backup and it appeared successfull. However, few minutes later I realised that the Circle profiles are gone instead. The a...
michaelkenward
Dec 07, 2021Guru - Experienced User
marekproc wrote:
Apologies, this was sent to a wrong forum without noticing.
Marek
Stuff happens. Not worth getting worked up about.
Did you also try here?
Circle Smart Parental Controls - NETGEAR Communities
marekproc
Dec 07, 2021Aspirant
Yes I did.
michaelkenward wrote:
marekproc wrote:Apologies, this was sent to a wrong forum without noticing.
Marek
