stestardi
Feb 27, 2017Aspirant
Configuring 5GHz Band in Genie
In both the new Genie for iOS and Desktop genie for Windows, I can't find how to configure the 5GHz band. Both apps default to the 2,4GHz band and there's no obvious way to select other bands. ...
stestardi
Feb 28, 2017Aspirant
It is. Even if it wasn't I'd expect there would be a way to enable or disable it through the Genie.
- michaelkenwardFeb 28, 2017Guru - Experienced User
Indeed. I see two vertical tabs for the different bands:
Tried reinstalling the genie? I have 2.4.38.
- stestardiMar 06, 2017Aspirant
Ahah! I didn't look there - I had to hunt to find it on your scrrenshot even when I knew what I was looking for. :)
I'll check when I'm back at home. Thank you!
- stestardiMar 28, 2017Aspirant
Hi michaelkenward,
Finally got around to reinstalling Genie and I do not have the tabs you have for switching between bands (see the picture in my original post).
Any suggestions?
Thanks!
Steve
- tsatryanJul 29, 2017Aspirant
I have the exact same issue - there are no tabs to select switching the view between the 2.4 and 5 ghz bands.
