Tecumsa
Dec 11, 2023Aspirant
Connect remotely
How do I connect to the router when I am traveling? I need access to one of the connected drives.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Use VPN to Access Your NetworkWhile many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
If you have problems in future, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities- TecumsaAspirant
Been there, done that before I came here for help.
That's good to hear.
Enjoy your remote access.
It is a pity Netgear killed ReadyCLOUD.
