Metalchili11
Mar 17, 2019Follower
Connected Device Icons not saving
The device icons for Smart Thermostat and Smart Speaker don’t update when saved. All the other icons I changed and saved updated just fine. Those are the only two that I’ve found that won’t update. Wh...
ebaltazar
Oct 04, 2019Star
Yeah, the app has been updated several times since I made my post, but no improvement. Extremely frustrating.
SDRick
Oct 21, 2019Tutor
Same problem here, some devices save the name and icon properly, others do not save and revert back.
just updated to app version 2.4.8.18 and firmware version V2 .5 .0 .38. Has anyone come up with a solution?
- ebaltazarOct 21, 2019StarWow, you're getting some of the icons to stay??? I haven't been able to get any of them to be persistent. Sometimes they stay for several minutes, but as soon as the list is refreshed, it's back to the generic icon.
- schumakuOct 21, 2019Guru - Experienced User
ebaltazar it might sound disappointing - here with the R9000 and some hands full of devices the icons and names stay, and are the same on the router Attached Devices _and_ in the Nighthawk App. But now does the R9000 support (much!) more device types in the Attached Devices than what the Nighthawk App can display. Said that, effects and issues depend almost always on the router model, the router firmware version, the number of devices (sigh, yes!), and to the least extend the App itself.
- sbollapaDec 22, 2019Aspirant
Any solution to this issue.. Its really frustrating that this simple usecase of have Address reservation doesn't work.
Also, my router is R7960 and it doesn't even show in Model :manfrustrated:
- D-ZigOct 08, 2020AspirantI am having the same issue name stays but icons revert back to just network not what I choose them to be for example camera, game if system etc... so frustrating.
SDRick wrote:just updated to app version 2.4.8.18 and firmware version V2 .5 .0 .38.
Subject thread is about the Nighthawk App and some select Nighthawk routers - your version numbers indicate it's an Orbi system and the Orbi App. While there is some direct relation, bugs might be different any any aspect.
