Metalchili11
Mar 17, 2019Follower
Connected Device Icons not saving
The device icons for Smart Thermostat and Smart Speaker don’t update when saved. All the other icons I changed and saved updated just fine. Those are the only two that I’ve found that won’t update. Wh...
MichiganMike_70
Dec 27, 2019Aspirant
So I believe I have just stumbled across the solution! When attempting to change the desired icon, you must also edit the name below. Even a one character variance will allow you to save the proper icon. So if you want to use the original name you had shut up, simply change it do a different icon and vary the name, then change it back.
gojmitch
Dec 31, 2019Initiate
MichiganMike_70
I have tried every possible combination of edits. What you suggested does not work for me. I have tried editing the icon and changing the name and changing the device type. I have tried editing the icon and changing only the device type and not the name. I have tried editing only the icon. You get the picture. Glad it works for you though!
I use an Orbi system.
- MAB12Apr 08, 2020AspirantHas anyone found a solution to the icons and names not saving? I figured the latest firmware would fix this but nope. The other great feature is the PoS seems to revert back to factory settings on a reboot or power cycle. I really wish I hadn’t purchased a Netgear product at this point.
- ebaltazarApr 08, 2020StarThere is no solution for that yet. It's definitely not high on their list of things to fix. I haven't experienced the return to factory settings after reboot though. That would truly be horrible!
