Metalchili11
Mar 17, 2019Follower
Connected Device Icons not saving
The device icons for Smart Thermostat and Smart Speaker don’t update when saved. All the other icons I changed and saved updated just fine. Those are the only two that I’ve found that won’t update. Wh...
MichiganMike_70
Dec 27, 2019Aspirant
So I believe I have just stumbled across the solution! When attempting to change the desired icon, you must also edit the name below. Even a one character variance will allow you to save the proper icon. So if you want to use the original name you had shut up, simply change it do a different icon and vary the name, then change it back.
D-Zig
Oct 08, 2020Aspirant
Tried didn’t work for me reverted back once everything refreshed
