bolg_3
Oct 03, 2022Aspirant
connection lost between CAX80 and Apple IPhone
Over the weekend I lost the connection between the router and my IPhone. The App won't let me log in. I have uninstalled and reinstalled the app, updated my password and log in credentials, rebooted ...
Oct 03, 2022Guru - Experienced User
And is Local Network enabled on the phone under the Nighthawk app as well?
Inputting the correct values?
Be sure your logging into the NG account profile first, then you should see the log in for the CAX80.
Might try a factory reset on the CAX80 and setup from scratch using a wired PC and web browser, then after the CAX80 is setup again, try the NH app...
bolg_3
Tried everything suggested, but no luck. Will continue to plug away at it.
Appreciate your suggestions and trying to help me out--many thanks!
