abruckla
Oct 05, 2015Aspirant
Content Filtering with Netgear Genie
When I attempt to individualize the filtering settings from within the network map, the filtering setting will not change from "default level on router" regardless of the device or the alternative se...
abruckla
Oct 06, 2015Aspirant
Genie version is 2.4.16.
The computer primarilly used to make changes has Windows 10. Many computers on the network, however, are running Linux Mint (I do not beleive Genie comes in a Linux compatible version.) I have a two other computers with Windows 10 and even 1 with Vista. The computer I use does not seem to make a difference.
Router is a WNDR3700v4. Firmware is 1.0.2.78.
DexterJB
Oct 06, 2015NETGEAR Moderator
Hi abruckla,
1. Have you tried uninstalling and re-installing the app?
2. Do you mean that the issue is the same with the other Windows 10 and Windows Vista computers?
3. Please try updating the routers firmware to the latest version (1.0.2.80) and check if the issue persists.
Dexter
Community Team
- abrucklaOct 06, 2015Aspirant
1) Yes
2) I have installed Netgear Genie on multiple computers and and experienced the same problem.
3) When attempting to upgrade the firmware it states "No new firmware version available."
- DexterJBOct 07, 2015NETGEAR Moderator
Hi abruckla,
You can manually flash the latest firmware for the router then reset and reconfigure it. Please refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
You can download the latest firmware using the link below.
http://downloadcenter.netgear.com/en/product/WNDR3700v4#searchResults
Dexter
Community Team
