Midnitejlr
Feb 25, 2023Aspirant
Correcting CAX30 connectivity
Since trying to reconnect to the internet I can no longer access my nighthawk app. Using the reset and default password do not work. Any suggestions?
Feb 27, 2023Guru - Experienced User
Can you access the modems web page with a wired PC and web browser?
- MidnitejlrFeb 28, 2023AspirantYes I can with a MacBook older one
- FURRYe38Mar 07, 2023Guru - Experienced User
What mobile device do you have the NH app installed on?
What FW version is loaded on the CAX30?
Other than the NH app not working, is the CAX30 working otherwise?
- MidnitejlrMar 16, 2023Aspirant
In answering your previous question, I do not know the which FW is in use but, the CAX30 has been back on line with Xfinity and working with multiple devices. Still not able to enter the Netgear app, Netgear Genie app or other Netgear websites
