ckasso's avatar
ckasso
Follower
Oct 21, 2017
Daily loss of internet access after enabling Circle by Disney on the R7000
We enabled Circle by Disney on the R7000 about two weeks ago.   Since then we have been experiencing (almost daily) internet outages.   Initially I just rebooted the router and the problem went away but more recently I've just disabled and then renabled Circle and that resolved the issue.
When the problem occurs I check the internet status on the router's admin status page and it always reports "Good".
With Circle we only have resrictions on a subset of the devices but when we encouter the problem all devices can not access the internet so we are not hitting any limits we established in Circle.
Anyone else using Circle and experiencing this problem?
Firmware: V1.0.9.12_1.2.23
Chris
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ckasso,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
    • EnglishOnly's avatar
      EnglishOnly
      Tutor
      Enabled Circle on my Orbi mesh network the other day and since the internet connection seems to drop every few hours.  If I disable Circle via it's iOS app the internet starts working again.
      I have firmware version 2.1.1.16 on my Orbi RBR50 and RBS50.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ckasso,
    Please make sure you do a factory reset after updating to the latest firmware.
    Dexter
    Community Team
