Ataraxy1
Aug 21, 2023Tutor
Deleting multiple devices
Is there a way to delete multiple devices from the network ...it has accumulated a ton of dormant devices
Aug 21, 2023Guru - Experienced User
Or factory reset the router and set up from scratch would clear everything out.
What model router do you have?
- Ataraxy1Aug 23, 2023TutorThanks. Would be more trouble to reset that delete them one at a time. Hope someone at NG sees this; the fix in the app should not be difficult.
